Following on from my ‘Fitting a Power Meter to a CU Part 1’ question here is Part 2.
My home installation includes a Lutron Homeworks system that is supplied by a dedicated CU image here - PXL_20211105_203655704.jpg - https://1drv.ms/u/s!AkQ39xZI1R4EkuBYCGWrqhjWgNTZlQ?e=W89acf
The power meter CT clamps will be tricky to fit into the available space so I propose to mount the power meter control box underneath the dedicated CU. My thoughts are to remove the live lighting circuit supply connection from each RCBO circuit, replace it with a matched cable that will run into the enclosure allowing sufficient cable to enable the CT clamp to be fitted and then returned to the CU and the circuit completed using a WAGO connector to join the removed cable to the newly installed cable.
Any comments on this method and the specification for the enclosure and conduit are requested.
Many thanks.
Many thanks.
