Discuss Fitting Hive 2 to a oil boiler in Spain in the UK Electrical Forum area at ElectriciansForums.net
jedder
Hi all,
Can you help,
I have bought a Hive 2 active heating (heating only version) to replace the thermostat we have in spain,
Its an oil combi boiler (Tifel - Eurofel 40 See pic)
The exising thermostat / control only has 2 wires goin to it from the boiler (see pic).
Can someone give me an idiots guide to point me in the right direction of wiring this so that the hive 2 controls it.
thanks guys,
Jedder
Might of been better to get a nest.
The back plate you have shown does not go where the thermostat is. You can put that next to the boiler.
The thermostat connects through your broadband connection
Don't put that back plate on where the thermostat is though. That just wants to go next to the boiler. connected like Lee said. The thermostat just runs off batteries and recieves a wireless signal. Can be fixed anywhere on the house (within reason)
Reply to Fitting Hive 2 to a oil boiler in Spain in the UK Electrical Forum area at ElectriciansForums.net
Anyone tell me where to connect the two wires that switch the boiler on via the programmer and the 2 wires that call for heat on the ufh control...
At the moment it depends on the weather on how well the central heating works, the main problem is the Nest Gen 3 thermostat only measures the...
i , i have a property to work on which has a programmable room stat upstairs and a programmable roomstat downstairs. S plan system , 2 zones. hot...
Hey everyone, hope you all had a good xmas. Got called around to change over an old style pin type thermostat to a hive one for a family member...
I have a Firebird oil boiler that is controlled by a Honeywell timer (no thermostat) that has channels for hot water and central heating...
