M
MrTrance
Hi, im fitting a shower for my mum in 10mm twin and earth, I have already got an mcb on the rcd side (40A). I am going ot get a 45a double pole isolator switch.
Is this correct?
CU - [SUPPLY-ISOLATOR] - [FEED-ISOLATOR] - SHOWER
Also will the plumbing work (also DIY), will the pipe from the cold water pipe have to be copper because if its plastic it will need to be bonded won't it?
10mm seems to be a ball ache to cut etc, any tips on terminating etc, looks like its going to be tight getting the cable from the loft to the CU (downstairs)?
Also on the isolator shall I just mount it with a 45mm back box in my bathroom next to the light pull switch? Then put a hole through the backbox and leave the cable dangling vertical so it doesnt bend in the back box when secured?
Hope this makes sense, im only 16, my college tutor is coming out to test it once complete,
Is this correct?
