L
Leesparkykent
so is the BNO company responsibly for installing from the head to a 3ph isolator (do they usually supply?)
I install the ryefield I guess- but won't they DNO/BNO have to install meters- so surely they would have to wire between
head>isl>ryefield>meter and me the contractor wires from meter>switch fuse>flat
You become the BNO. The DNO come an install the head and do the connection from head to isolator which you have leave tails for them to connect to. You then book a meter operator to come and install the meters. You have to supply everything. The DNO only supply/install the head and the meter operators only supply/install the meters.
