Discuss flexicom 24cx has Hot Water but no Central Heating in the Central Heating Systems area at ElectriciansForums.net
my flexicom 24cx has Hot Water but no Central Heating. the problem seem to be the analogue switch selector. it looks as if it is stuck on the off position and won't move to the timer or on position. Is it that I do not know how to move it??
Hi,if the switch is jammed,and will not move,this would be first on the list of possible reasons.
You could try turning the time clock,to see if it switches,just ensure you have "on" and"off" times,set.
You may require the services of a heating engineer/plumber,or spark,to check the timer and fit a replacement.
Reply to flexicom 24cx has Hot Water but no Central Heating in the Central Heating Systems area at ElectriciansForums.net
Hi I'm in a bit of a pickle trying to set up my hot water and central heating systems. Got a gas boiler with a pressure tank and a motor...
I have a fully pumped Y plan heating system using a Potterton EP2 programmer. Drayton MA1 Diverter valve. I have just replaced the Actuator head...
Hi Guys Changing my heating/water programmer and im stuck on the wiring ive gone from a danfoss to a Drayton and the wiring description is...
I've always thought I was quite good a wiring heating systems, I can do Y plan, S plan, UFH set ups, "normal" thermal stores etc, you name it and...
Hey everyone, hope you all had a good xmas. Got called around to change over an old style pin type thermostat to a hive one for a family member...
