Discuss Flourescent Fitting in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
O
One_of_them
hey,
got a 2x58W flouro fitting (tamlight euromod) and it has been suspended from the ceiling about 3ft using 2 screwed male hooks through the back of the fitting. The fitting itself has 4 BESA fixings on it and as these are not blanked off, or used I was wondering if they should be? The fitting is well out of reach of people but if they need to be blanked then whats the best option?
thanks
will try post a pic if it helps?
personally, i've never seen em covered but if you want you could cut some plastic off a bit of scrap trunking and glue or self tapper it over the holes
so they are generally just let un-blanked?? Im guessing the fitting was supposed to be surface mounted and has been altered to be suspended as its a sloping roof. IP4X was coming to mind that was all.
thanks
generally, out of sight , out of mind.
Reply to Flourescent Fitting in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Hi all, Disclaimer: I'm not an electrician and have very basic knowledge of electrical installation. We've been putting in a new kitchen into an...
Hi All, Just wondering if anyone has come across these downlighters at all? Trying to change all the batteries and inverters for a client, i...
Hi everyone Ive just had an electrical condition report conducted on a mixed-use property, and I am extremely surprised that after the last report...
Hi all, I've recently replaced my 4 inch centrifugal extractor fan fitting in the loft. I was hoping for some advice on if this is wired up...
Hi guys looking for advice here, Voltage on light casing! Just been out and bought a new light fitting (I will attach the photo of said light)...
