Currently reading:
Flourescent Fitting
Discuss Flourescent Fitting in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
O
One_of_them
hey,
got a 2x58W flouro fitting (tamlight euromod) and it has been suspended from the ceiling about 3ft using 2 screwed male hooks through the back of the fitting. The fitting itself has 4 BESA fixings on it and as these are not blanked off, or used I was wondering if they should be? The fitting is well out of reach of people but if they need to be blanked then whats the best option?
thanks
will try post a pic if it helps?
personally, i've never seen em covered but if you want you could cut some plastic off a bit of scrap trunking and glue or self tapper it over the holes
so they are generally just let un-blanked?? Im guessing the fitting was supposed to be surface mounted and has been altered to be suspended as its a sloping roof. IP4X was coming to mind that was all.
thanks
generally, out of sight , out of mind.
Reply to Flourescent Fitting in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
