Search the forum,
Discuss Fluke Tester in the UK Electrical Forum area at ElectriciansForums.net
L
lofty84
Hi Guys
Ive managed to save some money for a Tester and wondered if I could have some advise.
In the past I have used the Megger multi tester in college and one of the fluke varietys on the job and much prefer the fluke.
This is going to be my first tester and I would like it to be a fluke. Is there much diffenece between the C and B models because the B is a fair bit cheaper and if it is pretty much on par then I think this is going to be the best option for me.
I caN either buy it new of secondhand of of ebayand just wondered if its ok to buya second hand one and what I should set as the max im prepared to go to.
here are two I have been looking at
this is a C model
FLUKE 1652C Multifunction Tester | eBay
and this is a B model
FLUKE 1651 Multifunction Electrical Tester 17th Edition **Calibrated Jan 2014** | eBay
any help genuinely appreciated
You`ll always get the Fluke V Megger debate but stick with what you like, Me I`m a megger man all the way, cant stand the Fluke but thats only my opinion. As far as your question just buy the very best you can afford. Buy quality buy once as they say but there is little difference between the B and the C
I am a Fluke man myself. I think the main difference is the phase rotation function. If you only work on domestic it will be ok. Buy the best one that you can afford. I have a 1652C at home and use a 1653B at work.
If you can afford buy new then you know it hasn't been abused.
Also there are a lot of older versions on ebay which don't have the 'no trip' loop function.
the 1651 is recently calibrated. that's worth about £60, and it gives you a good indication that it's fully functional.
Im deffo going to go for a fluke as I prefer them. Not sure whch one ive you before now as I didnt know there was a c and b model. Does the B do the trip time automatically or is that the c
£60 or £600 pounds was that tele. Sound like its best to get a brand new one but I wasnt sure if people have brought them sencond hand before
can't help you with that one, mate being commited to megger. google the spec for each and see what the functions are.
Comparison of Fluke 1652, 1652B and 1652C:
The model change from 1652 to 1652B added a fast high current loop test, variable RCD current for customised settings, Pass/Fail indication of RCD tests, selectable voltage measurement L-N, L-PE & N-PE and the zero adaptor supplied as standard.
The model change from 1652B to 1652C added a phase sequence test.
what would you say is a good megger mft to get tele seeing as its my first one and all of my work will pretty much be domestic
i meant that the calibration cost is around £60. if going for a megger, a 1552 or 1553 will do all you need except phase rotation, which you would only need if you're doing a fair bit of 3 phase.
well I dont think they make the megger 1552 anymore.
Ive got £600 pounds to spend but if I can get some change great. dont know weather to go second. If I go second hand is there anythign to look out for, as I say its going to be my first tester.
check the for sale/wanted forum on this site. you can get a decent 2nd hand MFT for half your budget. that leaves £300 for some extra gear or beer.
there is a megger 1502 tester for sale buy MDJ but Im not sure how that compares to the 1552 I was reccomended so thought I would ask :)
it's the same but does not have auto rcd test.
the 1652 B will allow you to test type B RCD,s
Reply to Fluke Tester in the UK Electrical Forum area at ElectriciansForums.net
