Discuss Fluorescent lights and relays in the UK Electrical Forum area at ElectriciansForums.net
K
Ken77
Hi all,
I've just been to test a number of faults and have found a number of classrooms have relays on fluorescent lights? Can anyone think of a logical reason why someone would have installed them like this?
Thanks in advance.
Depending upon the classroom there are between 4 - 8 twin 5ft tubes per relay.
I can see any evidence of a timer, (not to ay one does not exist).
I haven't yet determined if all the classrooms are on the same circuit, but there is a relay in each classroom. What where you thinking?
you can't be looking at more than a few amps per circuit and if their controlled by a suitably rated switch can't see the point in relays really
Nor can I. I was trying to understand why this may a have been done as I am not familiar with use of Relays. Thanks for all the help.
Hi,
I've fitted them before, where this an external light sensor that switches lights off if the ambient light is good; but you can bypass this by switching the lights off/on at the switch. This was done as an energy saving measure, it's not always necessary to have lights on all the time.
Regards.
I worked on a few schools about 3 years ago , where we fitted Pirs through the carbon trust scheme and had to put relays in if there where 6 or more twin florrys in use , also installed relays several years ago to protect the contacts of the switch when switched of due to the back EMF ....
As already said , trace the switch feeds to the relays to where they go to..
Specific lighting contactors are good for their ratings..
i.e. A 20 amp lighting contactor is rated to 20 amps for resistive, magnetic and tungsten
To a degree, i doubt they would be vastly different.
Cheers
They can be vastly different, the switching duty will make a big difference, one which can handle heavy inductive loads will cope with a lot more fluorescents than one only rated for resistive/light inductive loads.
Well the schneider 16amp contactor states 10 x 58w fluorescent, do you have an example?
cheers
Abb do a contactor A26 45amp (high rating than the schneider) with a 25amp CB, and that can handle 35 X 65W. I was referencing a 16 amp, do you have one in mind Dave?
Cheers
Reply to Fluorescent lights and relays in the UK Electrical Forum area at ElectriciansForums.net
I am trying to understand how a relay system works and have designed a circuit and a ladder diagram all as attached for an 8 PIN relay, a current...
Thinking a 240V AC relay activated by two independent light switches could be used to switch power to a shared inline extractor fan. The fan...
I have three Aurora Fluorescent linkable (linked) under cabinet 'strip' lights (c.21cm each) under the kitchen cabinets and over the sink area...
Good evening! Don’t have a huge deal of experience with fire alarms but having to work on a conventional system at the minute with various...
Hi Guys I've fitted a few emergency lighting circuits to both domestic and commercial installs before, I've come across one I can't get my head...
