Discuss French rocker switch for light has 5 connections 3 black 2 red in the Lighting Forum area at ElectriciansForums.net
I am swapping a light switch in France for a motion sensor with two simple connections. The switch I wish to remove has two black into one connector a single black connector and two red into the third connector. It is paired with a second switch but I am happy to blank this if required or leave it permanantly in the on position. Earth wires seem to be an English thing :)
TL;DR
How do I swap this old french switch for a motion sensor with two inputs
To UK eyes, this looks like a fairly conventionally wired 2 way switch. I would expect the single black, one of the pair of blacks and one of the pair of reds to be the only connections to the other switch, leaving the remaining red and black to be the wires that would be connected to a single 1W switch, if fitted.
Reply to French rocker switch for light has 5 connections 3 black 2 red in the Lighting Forum area at ElectriciansForums.net
Is the following set up possible with a 3 Gang 2 Way Smart Wifi Switch set up (the black glass type touch ones) One of the 3 switches, switches...
I have a staircase about 25 feet long with two recessed lights (one up top, the other at the bottom). Each light is on its own 3-way switch, which...
Ok guys, first post so be gentle. I have a standard setup of two two way switches, one at the bottom of the stairs and one at the top so the light...
4K
Hi, I am looking to convert a 2 way light into just control by single switch. I have searched and looked for similar questions here, and found a...
