the pict
Mentor
Amendment 1 of the 17th Edition requires electricians to conduct a risk assessment of properties to see if they require surge protection.
Who holds such information ? the DNO, oh yes the people that you cant get on the phone because you need to go through customer services and select option 105 to speak to an advisor who has been out of school about a year and rekons a SPD is a legal high and has no idea where the technical department is and puts you through to billing who wants to know if your the account holder and cant talk to you because your not.... sorry data protection mate, line goes dead.....................................................So you ask the 75 year old retired teacher when the last time her home was struck by lighting and looks at you as if your some sort of nutter from the place up the road with iron gates and guys with with direwolves on leashes patrolling the electric fence,
I know I am probably over stating this but if AFDD,s & SPD,s are to be included with each circuit the board will be the size of the Ark Royal,
a 10 way dual RCD will be a 30 usable way board with as much cabling as the aforementioned aircraft carrier :eek:
It’s only one spd needed placed at the origin from a designated circuit in the DB domesticly anyway
I’m sure more information will become available in the coming months on this.
there is a table in the on site guide that whilst simple is supposedly the go to resource. also meant to factor in regional weather variation. I have a hager spd in my apartment owing to the metal structure/roof for the penthouses on top floor. makes it high risk for lightning
You will need to do a RA to see if the devices are actually required in your particular situation, AFDs have so far been reduced to a 1 module device, best buy BS 7671 and see the rules for yourself and not jump to unfounded conclusions SDPs are required whenever the installation passes through the building fabric, for example SPD in the house, if it's required, supply to out building SPD required at outbuilding, or that's how I rad what the NICEIC and more importantly the IET say, the NICEIC are only going from what the 18th say. Oh and apparently AFDs wont work on a RFC.
NICEIC used an example of a 3K rewire and a cost of the job against the cost of the contents of the house (10K in Darren Stainforths house) so if the property contents are worth more than the job, then you fit one.
I think that’s the jist?
I don’t have an 18th edition yet.
If they bring out an all in one (single module) device then I'm all for it.
Don't honestly think SPDs will be integrated into a single unit with MCBs and RCBOs They are already working on AFDDs , MCBs and RCBOs combined into a single way on a CU, please don't ask me how cuz I couldn't tell you.
I wonder what the acronym will be?
the one I have in my cu is 3 module, it has a type c mcb then 2 modules for the spd bit... expect they have integrated it into just 2 modules by now though.
