Discuss fronius or solaredge and solar quote in the Solar PV Forum | Solar Panels Forum area at ElectriciansForums.net
msr38
Hi
I would be grateful for advise. Is fronius( ? prima) inverter better than solaredge new HD wave for 4 K home installation. There are reported problems with solaredge optimiser needing replacement with time which would be a hassle. Are there any fire safety concerns with fronius. Can fronius be switched off in case of fire.
I got a quote of about £ 6200 from a highly recommended installer for complete installation for 4 K LG neon all black panel with solar edge new HD wave inverter. Does it seem reasonable. There is some extra charge for water heater controller and zappy charger( have electric car).
Thanks.
Fronius every time. Solaredge are not great and have appaling customer service when you have issues. If you must have Solaredge avoid the optimisers that mount under the panels (they will fail and panels need to be removed to trace insulation fault and replace) and have the standard inverter only.
hopefully will plan fronius prima on 2 strings if possible for 2 rows of 6 and 7 panels.
Battery(tesla) including installation in 6 K which is too expensive at present. Will battery in few years be better with fronius.
Can someone please recommend excellent solar panel installers in North East.
Does cost of around 6K appears reasonable for above mentioned system.
Thanks.
Reply to fronius or solaredge and solar quote in the Solar PV Forum | Solar Panels Forum area at ElectriciansForums.net
Good Evening All, I'm not an electrician but I'd like to pick the brains of those that are please. Note I intend getting a qualified electrician...
Good Afternoon All, So I have a new situation to me that I cannot seem to get a definitive answer for. I trained as an electrician and did...
HI Folks. This is my first post so apologies if it's in the wrong location. I recently installed a 3kw Solar system with an iboost diverter...
5K
Hey all, Thanks for any advice you might be able to offer. I thought I posted this earlier but apparently not, apologies if it is a duplicate...
I know how I was taught to test a RCD, 6 tests in all two no go, two under 300 mS and 2 under 40 mS with no load. But thinking about it not so...
