I hope someone can help me- I have installed new foglamps on my car. A new switch is also installed, and all wiring is good. I have also checked the connections at all points with a multimeter, and a probe. Turn the headlamps on, this enables the foglamps front and rear to be used. Headlamps and rear foglamps work OK. Turn switch to 'on' for front foglamps. Current at switch OK. Current at foglamp wires (power and earth) OK. Bulbs new, and light up using probe. Connect bulbs (Halogen H2 btw) with connectors to wires, and they don't work. I just don't understand! What is the problem? Hope someone can help, as it has to be obvious, I just can't see it!
