Discuss Full Refurbishment And Socket Heights in the UK Electrical Forum area at ElectriciansForums.net
EViS
We seem to be getting conflicting answers on whether the recommendations in Part M relating to installing sockets and switches at 450mm to 1200mm respectively also apply to existing dwellings undergoing a full refurbishment (and rewire). Can anyone put the record straight?
BC are involved on this project, however inspectors aren't always correct, so we would like to be armed with the correct information in the event they argue that the new sockets and switches should be installed at these heights.
The confusion seems to arise between various folk that refurbs (everything within the dwelling being ripped out) are also classed as 'new builds'. So there is no truth in this, correct?
In which case, at what height do you guys tend to install new sockets and switches on a refurb/rewire job?
either where they were originally or where the customer specifies. within reason. if I think it's a stupid place, I'll usually just tell the customer that and suggest an alternative
There should be no confusion really. If the building has been used for the same purpose previously then it is not a new build. As to heights that is to an extent subjective. All other things being equal I often fit to Part M in a refurb as what you loose on a chase upstairs you gain downstairs, assuming its a standard 2 floor house. But the answer to your question for me at least is what ever looks right.
Reply to Full Refurbishment And Socket Heights in the UK Electrical Forum area at ElectriciansForums.net
  • Locked
5K
I know how I was taught to test a RCD, 6 tests in all two no go, two under 300 mS and 2 under 40 mS with no load. But thinking about it not so...
Ok, I may be picking this up wrong or being a bit blonde but on the drawings it says light switches to be positioned between 900mm & 1100mm. Now...
21K
Deleted member 93172
S
Hi. New to this site so hopefully this question is in the right place. Working on new build atm, and sockets and switches are at the correct...
6K
