I think he put them at 45cm high. They were on the skirting board before.
Was it his intention to originally install the consumer below the stairs hence all the wiring is routed there.
Well he is managing the work and not doing the install himself apart from testing and connecting the unit. Something I wouldn't do again. He will never admit that he is wrong but it was his responsibility to let me know before the work if the unit had to be moved. The builders electrician who is doing Tey house wiring has said that he is prepared to move it next to the front door and incur any extra costs involved.
I was thinking that I would always have the option to move it back under the stairs in the future and and then the wago connectors I assume would no longer be required?
Not ideal but just want everything done now, even I'd not ideal. Will learn lessonsn for any future work.
I guess you prob don't want the awkwardness but I think we've decided that 1)you, the customer doesn't want it moving, and
2) apart from the other fellas opinion, it doesn't need moving.
Time to have a tough conversation
insist that you have it where yo want it (under stairs). if he won'tdo it, don'tpay him, get someone with mre that 2 brain cells.
Not quite understanding why he is managing the work and only connecting the consumer unit and testing and someone else is carrying out all the other installation work
Even more confused that all the cables are being jointed under the stairs to facilitate repositioning the consumer unit why not just connect the cables to a consumer unit under the stairs
[automerge]1589453202[/automerge]
I'd be encouraging for it to be relocated outwit the cupboard under the stairs. Nice, potential fire risk and potentially if the stairs catch fire a hindrance to exiting the property. At least adjacent to the stairs it will be passed and thus seen more frequently. Use a flush fit unit and it doesn't have to be ugly.
And the likely fire risk of a properly installed consumer unit is ????
Doesn't having the consumer unit adjacent the stairs present the same risk of a fire hindering any exit down the the stairs
Whether it is flush or surface I'm not sure I would want a consumer unit as an architectural feature and using a flush consumer unit would more than likely break through into the cavity which would then potentially bring it into contact with the cavity insulation with other possible fire risks
At least an understairs cupboard could be lined with fireboard if the perceived risk is high enough to warrant it
What is the position of the meter and service head in relation to the existing and proposed CU positions?
