Discuss Fuse rating in the DIY Electrical Advice area at ElectriciansForums.net
Hello
I have a question , when looking at a cartridge fuse that say's , 32A (32SB3) , and at the side it says 550V AC 80kA ( BS88.2 ) , can this be used as a 32A on 240V supply ! .
SpotBot
Hi SpotBot, welcome to the forum, I have dropped your link out to the DIY forum on your same post you made there as it gave no more info than the question you have asked here.
There is not a straight forward Yes or No answer here as your circuit design and your Zs readings play a part into what device you use as overcurrent protection, so in reply to your question then as long as you meet the disconnection times and your fusing is within your circuits limits then your front end device can be various kinds of over current protective devices.
Hi - if you have more info we may be able to be more specific :)
I think the fundamental answer is yes it is suitable for use on a 230v supply.
Reply to Fuse rating in the DIY Electrical Advice area at ElectriciansForums.net
I have a question which is confusing me and I cannot find a definitive answer and I hope someone can help. So I have a PC and Monitor and I have...
Evening all, I’m looking to install an outside light as a spur from a socket on a ring main. There is already a spur from this socket supplying...
Hello - I'm looking to help determine how many connections are allowed on my AC disconnect terminal lugs - Eaton DPU22R. I'm not seeing anything...
Hello All So I'm not long out of my college days and unfortunately I didn't have a lot of exposure to three phase and commercial wiring systems...
90s house electric issues continues 🥲 So after getting some good advice here I've managed to sort out some of the heating issues so thank you...
