Discuss Fusebox consumers units in the UK Electrical Forum area at ElectriciansForums.net
@Phil Thompson I'd agree on the SPD price. But not RCBO's. Hager RCBO's are £3/£4 more to me than the Fusebox ones. The price reflected a 14 way Fusebox CU that comes loaded with the SPD and a Design 10 12 way unit with loaded SPD.
If you're going by YouTube sparks then a few do like them: David Savery, Nick Bundy, Thomas Nagy, all have fitted them and, at the time of video, really liked them.
I have heard many good reviews on the Fusebox but from what I have come across if you are already on Hager regularly then the quality is a good reason to stay with them.. If you haven’t tried a Fusebox though, might be worth to try one yourself, see what you think?
What about the build quality though George.
I've not fitted one, I've seen one though my local CEF have started sticking them.
They looks quite well thought out, knockouts are positioned well and the layout is pretty well thought out..
They do look a little tinny in my opinion, the metal is pressed at the sides, of the CU I dont think it would really put me off... I get a decent price on Lewden A type RCBOs so I'll probably continue using them.
A bit off subject, but does anyone have any experience with m2 boards? I've been offered boards with spds and compact rcbos at a decent price, but I've never fitted any so if anyone has any experience with them Id be grateful.
Even after all these years I can't make my boards look that neat - hats off to you
I'm with you there. I can sometimes get them looking pretty neat, but not like that, especially an RCBO board. Very impressive!
Reply to Fusebox consumers units in the UK Electrical Forum area at ElectriciansForums.net
I’ve always been alright with the knockouts provided for Fusebox consumer units but I’ve got a job coming up where I don’t want to use the large...
I've been installing Type 2 SPDs in consumer units for several years now, and they always come as a pair, connected across L & E, and across N &...
I have a fuseboard change I need to do soon I’m putting in a FUSEBOX 7 or 10 way RCBO+ SPD My only concern is how I should run the pyro cables in...
I'm replacing my consumer unit (well, adding a second one, rewiring the house one circuit at a time, then removing the original one when it's all...
I wondered if it is OK to have 2 x Main Switches in the same consumer unit. One feeding the RCBOs in the House and one feeding the CU in a garage...
