B
biggles
got a radial circuit run in 4mm swa run from a 32a rcd unit with 32a breaker to some stables. which is also protected by a 30ma rcd. he wants an outside socket on his carport inbetween these to points. where do you find an outside spur to do this
if he's got stables, he's got horses. therefore he has got spurs...... ssssimples. take a feed from his riding boot.
Your main problem, will be the fact that when you cut the cable to add joint, will there be enough cable to do it?
Need more information, i.e. where is the SWA running currently?
Once you got over the lack of slack, if this radial is a Final ​circuit why are you wanting to find a waterproof spur, just fit a water proof socket
if he's got stables, he's got horses. therefore he has got spurs...... ssssimples. take a feed from his riding boot. lol. didnt think it was running 32 amps through the back of a socket also need to fuse down to add a light. 3 x 4mm cables in back of an outside socket wont go. already put swa in from cu at stables back to carport to an out side socket and light.
into the socket out from there into a fused spur in side, out from there to the next point socket etc then the 4mm's will fit ,and dont forget this type of work is notifiable
