Search the forum,
Discuss Fused spur from an immersion switch? in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
J
jimk996
Need to put some power to a small wall mounted electric heater that takes will take it's power from a 5 amp fused switch outlet. It's in a flat and the least disruptive way I can see of doing this is by running a 2.5mm T&E cable from the immersion switch to the 5A switch fused spur then connecting the heater to this. The immersion is on its own 16A radial. I can't see anything that may not comply with regs on this but a colleague thinks different. Anyone provide clarification on this?
thanks
Just a quick thought the ON Site Guide gives you a nice percentage page for all this Lights, Sockets, Heaters Etc the name has left my brain...
Here we go yet again I thinks
thanks
- - - Updated - - -
Or as they say Jesus wept lol
thanks
If the immersion is used as the sole means of hot water...No...ideally it should remain a dedicated radial
If the immersion is not or little used..(standby if boiler fails)...you could do this by using a 20a 2way grid switch as a changeover switch. Wire it so either the I/H or bathroom heater can be used independantly but not at the same time.
Immersion elements are usually around 12A so if conditions permit you could upgrade the main fuse to the circuit to 20A
- - - Updated - - -
Why would he want to upgrade the circuit to 20A
- - - Updated - - -
Too late
- - - Updated - - -
Is this what I'm up against !!!!!!!!!!!!!!!!!
New posts
Reply to Fused spur from an immersion switch? in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
DIY'er question: I have a singe switched fused spur above my kitchen counter, providing power to an undercounter fridge socket beneath it. The...
Hello. I live in a new build house with a separate garage. The garage is connected to RCD in the house to a 16A circuit breaker. The cable from...
Hi, Have normal fused immersion heater switch. I would like to add a smart wifi switch to it so when my Solar is producing over 3k spare, going...
Hi, I know it's best practice to run an immersion on a dedicated circuit but am I OK with the following A new heat pump is being fitted and it...
Extremely newbie question here. I'm looking to remove a redundant electric fireplace heater - it's wired into a switched fused spur on the wall...
