P
PLW
I have a feeling I may be horribly confused and need someone to set me straight...
As stated a fuse will blow at twice the rated value so a 5A fuse could potentially blow at 10A. However when using a fuse as a means of protection, you obviously want the fuse to blow to in order to prevent overcurrent. As it is true to say that a fuse will blow at twice the rated value, if we're talking about a dishwasher rated at 1005 watts using 1005watts divided by 230volts we get 4.369amps so a 5amp fuse would be used. As previously stated a 5amp fuse could blow at 10amps. However in order to protect the wiring you'd want the fuse to blow at less than twice the rated value, otherwise wouldn't overcurrent continue meaning the fuse wouldn't blow?
If I'm correct we want the fuse to blow in order to stop current above 5amps flowing through the circuit, but if a fuse can blow at twice the rated value how does this work?
Thanks.
Thanks.
