Discuss Garage CU and RCD in series in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Evening all - got a question that i think i no tje answer but need some assurance!!
Putting a sub main (garage CU) with standard sockets and lights.
Feed to garage CU from suitable MCB in main board that IS RCD protected.
Now........testing ... Most garage CU come with RCD, my understanding is RCD in series a pain so looking for the correct way to test - or is it easier to get a sub main with a 100A main switch no RCD? Thanks
Thanks both - problem is the main DB is split load 2xRCD board so all MCBs are RCD protected gggrrrrrr!
i have a mk sentry metal db dual split rcd and just slid the rcds and mcbs up the din rail to make room for an mcb between the main switch and the first rcd. put a short buzz bar to connect it. 20190121_163116.jpg
Yes Change to Main Switch
How would you record the install? MWC for the main DB to garage DB ( assuming using MCB that is there already and has 6mm cable just re-routing) and EIC for garage DB
House CU to garage is “new circuit” and garage DB is a “new CU”, so both require an EIC to be issued and LBC notified.
Reply to Garage CU and RCD in series in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Hi My main feed comes into the garage, feeds into the meter and then out to another box with a 60AMP fuse then into the house...
Hello! I've been racking my brain this evening about some RCD selections. I've been doing some work for a solar installer, and they've asked me...
