If its in line its an easy job, if ive got do a ring and not spur connections id pay
Spur connections as in each socket has a 13A fused/switch beside it? or do you just mean a radial?
You would like to add 5 sockets via a spured fuse?
Garagebox 16amp mcb --- junction box --- double socket (DS) --- DS --- DS ---DS. 2.5mm2 twin earth cable. Straight through checked this with the Man at BQ says it will be fine and also told me a local shop get the canle sockets from cheaper than screwfix! Thanks for the help guys. Understand the safety issues but would mess around in the house! Only the garage and got to breakers between there and some 23amp or so rated cable so should be fine ;)
Looks like John wayne did the Job, and who would add 5 sockets on a 2.5 mm2 cable? well not me, 4mm2 every time, 2.5? wheres tonto?
yes haha, nothing wrong with a few sockets on a 2.5 cable, but lets be truthful, if we were adding a new radial circuit to a garage then 4mm2 would be the minmum size, TBH a 6mm2 but 4mm2 at least, I just don't get the 2.5 thing, it has amature DIYer writen all over it, I don't believe there ever was a spark, the OP did it lol.
was stopped dead in my tracks by this comment......
whats wrong with 5 sockets on a 2.5mm / 16A mcb ?
s
like I said Biff in post 26 theres nothing wrong with it as such, but a real spark with the exception of yourself of course would add a 4mm2 at least to an outside building if a radial, if you would let me know where your at I will send one of the lads up to give you some tips :icon10:
I added a 6mm2 to my shed/garage, can't imagine running a 2.5 to it, mind you I have a couple of beer fridges and a washing machine in there.
