5 sockets on a 16 amp radial that is ......................fooking pointless. What exactly are you going to use 10 outlets for at once that is going to keep you under the max rating of the mcb. Me thinks ...................not much
Type B circuit breaker - standard installation? - 20A breaker for a radial @ BS 61009, been a while since I looked at regs :D
I have just read a thread where Biff and others were talking about one member who was going to add 4 sockets off a ring main in an outhouse and they all slated him due to the fact one socket had a tumble dryer plugged into it which was rated at just under 10 amps, now fast forward to this thread, why does the op need 5 twin sockets/ and whats going into them? come on 2.5?
OP could be creating some sort of Fritzel type deal with his 12 power outlets @ 16 amps they will have to pick and choose which appliances to turn on :D
(1) fridge freezer and also a chest freezer, (2) tv and small patio heater, (3) washing machine, spur off it to a 6ft fluorescent light,(4) arc welder, (5) lawn mower and battery drill charger, another extention lead with a car battery pugged in and the garage electric door spurred off, it's amazing what can happen on 5 double sockets in a garage, especially if the wife likes to watch eastenders haha
Was going use 4 sockets for freezers and then in the second half of the garage gota small workshop router / extractor etc. also gkt a tumble dryer jn there.
Thanks for the clarification Bud, I would suggest a 40 amp supply to the garage myself, I would add a 10mm2 3 core armoured to a small 4 way consumer unit, have the 4 freezers connected to 2 twin sockets on a 20 amp radial, and have 2 sockets on a 20 amp radial for the washing machine and for general power tool usuage, due to the fact it will be very rare both are run together 20 amps should be adequate for that radial, and have the fluorescent light in there on a 6 amp MCB, you could always add an outside light to that also if needed in the future, as the router is small power you have no main issue, however if you do intend to add other power tools like lathes and power drills then a ring main may need to be concidered rather than a radial, you need to think about realistic use in the garage and plan ahead, a 2.5mm2 cable will not be adequate for your needs after your comments.
firstly i never slated the OP , i offered constructive advice that the shed appliances would exceed the 13A available from a spur ,
secondly , go look at the picture on page 426 of the current regs book , count how many sockets are on the example of a 2.5mm radial....
then come back and try and argue your point that 5 sockets or more cant be wired in 2.5mm.
No need to argue Biff, a 2.5mm2 cable to a garage with 5 double sockets connected to it will not be acceptable, in a house on the first floor with a tv and a video recorder and maybe a stereo of course no issue, a garage no, not 5 sockets, and I don't and won't look in the regs about it, no need m8 been in the trade too long to know it is the minimum standard, the whole book needs a shake up, and any spark adding 5 double sockets to a garage on a 2.5mm2 radial need not apply to MDJ electrical contractors Ltd for a job.
Is this an ok way to wire in the sockets as described in my first post? Goin screwfix get the stuff tomorrow.
i think its been made clear early in this thread that your best bet would be to get an electrician in to come and do the job properly....this would include install inspect and test....a cert would also be issued....
plenty of folk in here round the potteries
this thread smacks of a mega wind up. if it's not, i cover stoke. be glad to quote.
