K Kiers1970 Feb 29, 2012 #1 Hi Lads, Any of you know if any other make of RCBO will fit in a GET board?
K Kiers1970 Feb 29, 2012 #2 Looks like Crabtree will, tight at the top though, hope the existing CU is wired nic and neat!
O Octopus Feb 29, 2012 #3 IMHO you should fit the make of RCBO's or MCB's as per the make of the board.
Richard Burns ~ Mentor Arms Feb 29, 2012 #4 I think, but I am not sure, that hager fit in a GET board, although the recommendation is not to mix brands in a CU.
M MarkieSparkie Mar 1, 2012 #5 I can confirm that Hager MCBs/RCBOs fit GET boards, but obviously the BS EN 60439-3 consumer unit type testing conformity will be compromised in doing so. Last edited by a moderator: Mar 1, 2012
K Kiers1970 Mar 1, 2012 #6 I think I'll let common sense be the deciding factor here. Cheers Lads, thanks for the help.
