Discuss GFCI Problem in the UK Electrical Forum area at ElectriciansForums.net
You have lost your neutral somewhere and if you are just having problems with 3 receptacles it has to be the GFCI
Thanks. I think I am going to head to the store and pick one up and see if that is my issue. If not I am not quite sure what it could be and I will probably have to call and electrician.
Good luck Breck09 just make sure it’s tamper resistant. It will have on the box TR
Just an update, went to Home Depot this evening and picked up a 20amp tamper resistant GCFI outlet and hooked it up and now all 3 outlets are working as intended. Thank you very much for your patience and help with this. If you are ever in Grove City (Columbus area) Ohio let me know and I will buy you a beer or two.
I’m proud of you Breck09 and you never gave up. Thanks for the invite
Reply to GFCI Problem in the UK Electrical Forum area at ElectriciansForums.net
Extremely low voltage on 120v line Hi, I’m not an electrician but my home has 20 amp breaker that has only one outdoor outlet on it with a GFCI...
Legends, need some advice. I am a 12v automotive electrician, but have had a side project building a concession trailer for my dad. We have an...
Hello. I am new to wiring and could use some help getting this circuit wired in the kitchen . I am trying to get the source power to the GFCI and...
Replaced our old 240v hot tub with a new one, which also uses 240v for motors, heater, etc, and 120v for low amp LEDs and touch screen control...
Having trouble figuring this one out. House was built 5 years ago. Eaton box and breakers. Over the past 3 weeks, the bedroom breaker keeps...
