Discuss Gland for MK 32A commando plug in the UK Electrical Forum area at ElectriciansForums.net
Anyone know what gland for is needed a MK 32A commando socket to hold a flex ??? Its got a thread for a gland (see pics) I expect its a stuffing gland if using flex but its an odd size.
Its for a commercial single phase oven 16Kw
You lot might be a preserve of knowledge but Charlie youre still boring, but nothing wrong with that mind I don't discriminate. And of course its not a 16KW oven, I mean ---- man that's a lot of cake
Had similar issue with brand new plug. I just put the black gland in a vice (gently) and turned anticlockwise. Took some heft, but it did eventually come loose. There should be 3 plastic jaws that grip the cable sheath that move in/out when rotating the gland. No tools necessary (less the vice😉), “should” be tool less install..ya think?
Reply to Gland for MK 32A commando plug in the UK Electrical Forum area at ElectriciansForums.net
Hi all, I've just installed an APC 6KVA SRT6KRMXLI. As a computer network engineer and electrician, I was a bit baffled by the 35mm gland that...
Came into work today with a fairly urgent requirement to install an instant hot water handwash unit in a small commercial kitchenette/servery -...
I'm planning a replacement for my existing domestic CU and would like to have it sanity checked before I get an electrician involved. The main...
4K
Was having a poke around the old man's house today. Anyway. DB is under stairs (18th ed following a recent extension. Not done by me but it's...
Hi all, Recently a mate had a new kitchen fitted, he's gone for an induction hob and pyrolytic oven, no gas at the property. At 1st fix a single...
4K
