Discuss Gland ?????????????? in the Electrical Tools and Products area at ElectriciansForums.net
Cheers Dave, had a look but couldn't find what I'm after.
its for a garden spike light with flex which will be going in to flexi conduit, so to fit conduit one end and compression fit flex other.
The only way I can think of achieving that would be to a glavanised coupler or two of these glued back to back.
https://www.NoLinkingToThis/p/tower-female-conduit-adaptors-20mm-black-2-pack/77225
thanks for the input, i could use a coupler and some PTFE tape if i cant find a gland, would prefer a gland though
I had a quick look on RS to see if there was anything more suitable... I only looked at the Adaptaflex range and they didn't have anything that would make the job easier. It's a bit strange as I highly doubt your the first person to want something like this.
I've used these for flexicon, a dab of silicone, never had any problems:
https://www.NoLinkingToThis/p/tower-male-corrugated-conduit-adaptors-20mm-black-5-pack/51169
Cant you just push the flexi conduit into a female adaptor and use plenty of solvent conduit glue? Thats how i do my rods when i go in the side of a pit, if not it will fit in a 32mm compression gland
Reply to Gland ?????????????? in the Electrical Tools and Products area at ElectriciansForums.net
With next week forecast for rain, we thought we’d take a moment to explore what IP ratings are and why it is important to know their meaning. In...
https://www.gprokit.com/lever-junction-box/lighting-control-box-flexi-box Anyone used these before? Essentially a Klik box without the added cost...
On a domestic Cu 60 amp would live and nuetral tails cause eddi currents of any significants if the tails were run in sperate metal conduit but...
Anyone know if any of the big wholesalers stock White flexible conduit ? I have a customer where I was going to use black flexi But now they want...
Afternoon, I need to change a memera 2000 6amp mcb for an rcbo that is compatible . I believe the mentioned mcb are not made anymore. Anyone got...
