T
TomT
I ran a completely brand new line from the electrical panel to a single pole switch which controls 4 GU10 LED Dimmable lights connected in parallel, every time i flip the light switch i blow the breaker, i tested the lines for resistance and was still able to check physically if the wire is bent/damaged/broken/etc everything seems ok, i replaced the breaker for a new 20, and still the same problem, any suggestions anyone...help
wire used:
Southwire 250 ft. 12-3 Romex NM-B W/G Wire - Yellow-63947655 - The Home Depot
GU10 lights
EcoSmart 50W Equivalent Bright White (3000K) MR16 GU10 LED Flood Light Bulb (E)*-ECS 16 50WE WW FL GU10 120 TP - The Home Depot
cans/fixtures:
Globe Electric 90540 4 inch Recessed Lighting Kit, Swivel, White Finish, Spot Light, Contractor's 10 Pack - Complete Recessed Lighting Kits - Amazon.com
wire used:
GU10 lights
cans/fixtures:
As an Amazon Associate we earn from qualifying purchases.
