Dave 85
Hi lads
Did a job a little while ago, swapping old down lights for GU10 LED ones and of about 20 there is one (the only one on that switch) which flashes on every 20 seconds or so when the switch is in the off position. Tried it with a different lamp (same type) and replacing the switch but didnt solve the problem. Gotta try fix it tomorrow.
Solutions I have heard of so far are:
Replace switch with double pole....trhis could prove tricky as no neutrals at switch
Try a different brand of LED lamp
Install a capacator (can anyone elaborate on this last one?)
Very much appreciate any thoughts/advice/past experience from anyone
Cheers
yep. try a snubber across the L-N of the lamp. these can be capacitors or a combo. resistor and capacitor.
