Discuss GU10 lighting circuit problem in the UK Electrical Forum area at ElectriciansForums.net
Definitely sounds like faulty bulbs. The LEDs ought to consume less power than the halogens they are replacing (which typically consume 20-50W each in GU 10 size), and since you said you can run the fixture with all six halogens installed with no problem, your problem is not simply that six 7W LEDs were too much for your circuit in combination with all the other loads.
See if you can isolate the problem to one specific bulb out of the six by only installing one bulb at a time. It could be a short in one of the bulbs due to a manufacturing defect.
Reply to GU10 lighting circuit problem in the UK Electrical Forum area at ElectriciansForums.net
I have a street light circuit on land I rent out. I need to replace 2 of the bulbs. 1 of them is an old Philips 55W SOX Plus, the other is a...
I really need help with this puzzler. First - I am moderately 'skilled' in day-to-day basic wiring. My puzzle: I am trying to replace a...
My kitchen has track lighting. It consists of three halogen light bulbs. I've had the fixture for more than 25 years with no issues. Last night...
Hi we are replacing light fittings in our home. Im confident with the fitting aspect, but have run into doubt in making the right choice of...
I have an issue with a home lighting circuit 6A RCBO provides power to 13 bulbs which randomly keeps tripping, when I say randomly it keeps...
