Discuss Haphazard lighting layout. in the Industrial Electricians' Talk area at ElectriciansForums.net
If it's the same product then yes. It comes in a case with all the bits and think of the time saved trying to lift boards etc
Just bought some Ashley non maintenance junction boxes - they're brilliant, very quick push fit and loads of room in them. I'm not going to use anything else from now on.
Think you can get dryline junction boxes which you can fit in the ceiling and then screw the rose/fitting to it. That way the wires are accessible but not actually in the light fitting.
Reply to Haphazard lighting layout. in the Industrial Electricians' Talk area at ElectriciansForums.net
Hello all. So I am sure the expertise on this forum will be able to decode this very easily. But it has completely baffled me. I'm in training so...
Hi guys, Been asked to fit 2 lights and a switch, which in reality turned out to be rewiring a multiple PIR setup to a single switch, adding...
Hi, I’m new to the forum. Thanks for letting me join. Asking for some diy advicd… I’m trying to add a couple more security lights to the existing...
