Discuss Hardwiring under cabinet lights in the UK Electrical Forum area at ElectriciansForums.net
Why cut off the melded plug top when you can fit a 13a socket on a patress in about 5 minutes flat.
So much easier than faffing about cutting off plug tops and using JBs.
What happens when the led light fails?
The customer is faced having to unpick a Jb
If it were simply plugged in they could quickly and easily replace the light themselves
Simply because a 13a socket on the lighting circuit is bad practice. If you must have a plug and socket use a 2a or 5a one.
It's common to refer to them as transformers though. It isn't really a problem in most cases, and is better than trying to explain the difference between an electromagnetic device and a switch mode power supply to someone who doesn't really care.
but what about LEDs that will run on a.c. as well as d.c?
AC/DC???? It all sounds like a highway to hell to me.
:):D:p
Seriously though... if there’s space down the back of the units, just drop the lights down there, driver on top of unit, hidden... and plugged in.
Most of these LED kits come with one driver with a number of outputs. If plugging in multiple lights into one, just make sure the total load on each driver doesn’t exceed the max stated output of the driver.
I installed a double outdoor socket, in readiness to plug some Philips garden lights into. Forgot to tell the guy installing my decking; he plugged in his 110v chop saw into it, which tripped the lighting mcb, when he went to cut some decking.
He plugged his saw into something else, and I reset the mcb when I got home. But we survived.
Genuinely interested in the various answers here!
If it's a dedicated lighting circuit, why risk someone plugging in a big Hoover? Just put in a JB and then no-one can do that?
If it's a rfc or radial for sockets, just use a plug and connect the driver that way...I know my lights are plugged into one outlet of a double socket, the other socket powers the fridge/freezer.
Horses for courses?
Horses for courses?
Nobody is going to climb on top of the cupboard to plug the Hoover in :)
DPG, if you saw the way the "professionals" wired this place...you would have to plug the vacuum cleaner in on top of the units!
Seriously, what i meant was, if, for example, you wanted to plug the extractor fan in, then a handy double socket would be the thing. But...if that socket was off the lighting circuit, you might not want to do that...even though the fan is fairly low powered. i just think that if you see a 13A socket, you might expect it to be for that type of load, whereas, to put a 13A socket on a lighting circuit, just to power some LEDs might be confusing. I expect no-one will die as a result! It's a bit like pump nozzles at the filling station...some supply diesel, some supply petrol...always nice to be sure what you are getting out of the nozzle!
It does not specify the purpose of the circuit it gives suitable methods of connecting a luminaire to the fixed wiring.
[automerge]1567461593[/automerge]
I never said a 13a socket should not be used supply lighting. I have said a 13a socket should be on the lighting circuit. Not the same thing at all.
In #21 you refer to this as bad practice.
Make your mind up mate. You're going round in circles here.
I have said a 13a socket should not be on the lighting circuit.
Typo corrected. ('not' added).
There is no Regulation prohibiting this in fact it is a suggested method of connecting a luminaire. I agree in some instances using one in an inappropriate place may cause problems and in such instances 2A or 5A maybe the correct method, I have 2A at home. One amendment to the 16th Ed removed 13A sockets from the suggested list but was reinstated.
Reply to Hardwiring under cabinet lights in the UK Electrical Forum area at ElectriciansForums.net
Hi, I am restoring an old art deco, wall mount medicine cabinet. The cabinet has an 18” fluorescent light tube on each side. Before I put a lot...
Hi I'm in need of some advice. First of all i'm not an electrician but do have an understanding of electrics as i come from an electronics...
My wife has a electric heated airer, our dog chewed through the cable and I thought it would be no different from rewiring a plug. It's not. I...
I have been asked to change cu from old fuse board which has 6 fuses. Only 4 fuses are used. The first fuse feeds cooker circuit. This is not used...
Hi.. Newby here.. I have a couple lights holders/bulbs on the end of a flex plugged into the mains 13Amp plug. I want to put an inline switch on...
