hello guys
I need to put some plastic switches on some switch drops with no Earth and replace the backboxes.
The plan is all class 2 fittings and plastic switches
I have been told these old 12mm conduits and backbones are made of nickel and my multi tool won't cut them, i suspect they had wood blades as they can't be that hard to cut.
Has anyone tackled a similar job with any advice?
hello guys
Cant see any fixing lugs
It is probably 5/8 conduit and Rob is probably correct, that is the cpc unless it has been butchered.
scrape a bit of the box down to bright metal. then get Tester and a wander lead from MET to box. check resistance.
Yep, boxes look like cast to me. They will split with a cold chisel.
