Head Torch & Work Light
Led lenser for sure for headtorch. 7 year warranty on registered products. Outstanding quality. Buy wisely though as plenty of fakes about.
A work light that uses your tool batteries would be a good choice.
got 2 flee bay had mine 2 years so far .
Best place to get an Led Lenser Andy?
3 AAA batteries required. (included) for that on amazon me I would go for a rechagable batteries one .
[automerge]1572721987[/automerge]
I tend to use mine taking the hedge hog for a walk at night .lol.
They are around double the price. They look good though and allow you to use batteries too. I will see if I can see it any cheaper as I’ve a limited budget.
I use a h7r.2 which is a brighter version and rechargeable via USB. The rechargeable battery has lasted about 4 years I think so far so worth the extra. You can still slot AAA batteries in too.
I’m looking for a decent head torch and work light. Does anyone have any suggestions please?
I bought the one below in the link. Black diamond icon. It’s very expensive but I wanted one which had quite a large power pack so that the rechargeable batteries would last all day. In addition I wanted one which had the centre head strap, I.e. one that goes over your crown as well as the sides of your head, as others I have had always slip. It is also very bright.
I use mine all the time so it has definitely been worth the buy, however if you are only using it once or twice a week then it may not be worth buying such an expensive one.
Got both types,and the ones that sit waiting for an emergency,are handier with batteries,not rechargeable,as quicker to press in to service when found flat?
Regulat daily need,would lean towards rechargeable.
For a small work light I would recommend these Nebo lights USB chargeable and extremely bright obviously battery life is less on full but they're dimmable also
They've a clip / magnet or can be hung on a hook body is aluminium, I don't expect the hook to last forever but it's a good buy
I've got 3 thought I'd lost one, bought 2 which were £16 each and found the original
bought mine from ebay. recargeable 18650 batteries, last ages. could buy 5 more and still cost less than that.
That torch is described as 90,000, 15,000, 8000, and 1000-1999 lumens all in the same listing. I take it it's bright then ? ?
