Discuss **HEATING GURUS** Help!! Ferroli boiler issues in the Central Heating Systems area at ElectriciansForums.net
A
arctic
**HEATING GURUS** Swapped a wireless stat to a wired one due to connectivity issues the customer was having. The boiler is a ferroli domicompact f24d and the new Stat is a select thermsave, bog standard room stat. Now ever since the boiler is showing a F9 fault and producing no hot water, which the tech line tells me is a water heater sensor fault but very odd as only appeared when I swapped the stat??? Any ideas lads would be greatly appreciated!
Well at a guess I'd say you've caused a bit of damage whilst you were Ferlinghetti around with the boiler. Probably just disturbed a connection somewhere..........hopefully, otherwise you could be paying for an expensive repair
Reply to **HEATING GURUS** Help!! Ferroli boiler issues in the Central Heating Systems area at ElectriciansForums.net
Hi, So I'm trying to understand what's going on with my off-peak electricity supply, as something's wrong with it and I'm trying to determine if...
Hi I've just started renting a new flat with my partner and we're having some energy problems. The boiler that we have is as I understand it, a...
4K
1st post and I’m not a heating engineer/electrician so apologies for lack of proper terminology. It’s a long story but in essence I had a new...
9K
Hi, Since getting back into the trade a few years back have installed controllers for boilers with room stats etc & the odd new S plan system -...
6K
