Discuss Heating programmer problem in the Central Heating Systems area at ElectriciansForums.net
Recently had installed a timeguard 2 channel heating programmer. When I set program for CH starts pump but does not fire up, if I also set program for water then CH comes on. This causes a real pain when setting timer, as I have to set 3 times 7 times 2 settings =42! Also I would prefer a remote unit where the settings are made from remote rather than from wall mounted until next to old - non combi boiler, as need changes daily. Advice welcome thaks Ps have contacted installer no response.
The programmer may be set to fully pumped rather than gravity. There should be a jumper link on the back of the programmer and it should be on G rather than P. It probably comes set to P when it’s brand new out the box.
Thanks, I will remove and have a peek
Make sure you isolate the supply 1st. Let us know how you get on. If you wanted something you can control remotely then I would take a look at hive. You could control heating/hot water on the thermostat or via app on your phone. The two channel receiver would replace your existing time guard two Chanel programmer. You would just have to set it up in gravity mode.
Reply to Heating programmer problem in the Central Heating Systems area at ElectriciansForums.net
i , i have a property to work on which has a programmable room stat upstairs and a programmable roomstat downstairs. S plan system , 2 zones. hot...
Hi all @ef.net, I'm a newbie to the forum; this is my first post. The Danfoss FP715si programmer that had been in use for about 8-9 years began...
Hi I'm in a bit of a pickle trying to set up my hot water and central heating systems. Got a gas boiler with a pressure tank and a motor...
My customer wants to be able to switch his heat pump (3.5kW) for his swimming pool on and off remotely, he also wants to be able to set times for...
The unit only heats water using the programmed boost and when pressed in the 1 2 or Cont boost function. I have checked the off-peak time which...
