Discuss Heating under floor heating help please in the Central Heating Systems area at ElectriciansForums.net
714gold714
Hello there
If i could have some advice please on a heating system would much appreciated
Done a few heating systems in the past with s & y plan systems however an extension i have first fixed the customer is now installing under floor heating. There is a circulation pump, a manifold and two port valve there from memory.
I have ran a there core twin and earth and a feed to the thermostat for the new zone in the kitchen, a feed to the manifold and where the pump is located and two three cores from manifold to the existing airing cupboard where there is a wiring centre and boiler for the existing heating system.
Could anybody give me an idea how to wire this heating system please
Can you re word it so it makes sense?There core or three core? basically how many cables you got going from what to where? Then we might know your setup
sorry
I have a three core to the thermostat in extension- where the under floor heating controls are located
I have a feed 20 amp supply - where the under floor heating controls are located
I have x2 three core to from where the under floor heating controls are located-the existing house airing cupboard wiring centre
sorry
Why can't you follow the wiring diagram which you used to decide how many cables to run? Or did you just take a wild guess at what cables you need?
If it's like most systems you don't need a separate supply to the ufh as it can be fed from the boiler supply (feeding it with a separate supply will need a relay to link to the boiler controls) you'd normally need L,N and SwL from boiler to ufh manifold and a L and SwL (and possibly N) to the stat from the manifold if it's a wired one.
It's sensible in my opinion to include a three pole isolator at the manifold to allow isolation from the rest of the heating system.
Reply to Heating under floor heating help please in the Central Heating Systems area at ElectriciansForums.net
Hi all, taken on a new build project and they have quite a large property with three separate manifolds. I have wired before with one manifold but...
Hello, I hope you are well, I have fitted a few Nests but only to Combi, S and Y plan systems just been looking a job where I’m doing the kitchen...
I've pretty much sussed out the wiring for the radiators and underfloor heating, thanks to help from the forum. I do have one more question...
In July I moved into my new home with Schluter DITRA heated floors in the bathroom. The floor quit working in December, and my GC and a rep from...
