why do you use different colours? its alot harder to read for me.
i was pointing out that your statement was slightly misleading and could be mis-understood being on a electrical forum. An electrician turning on an appliance after he/she has wired controls will not be breaking the gas regulations so even if you personally wanted the electrician not to turn the appliance on they would be safe to do so.(unless they are removing a case which seals the combustion system).
i fully understand the "way it works" on contracts being a heating engineer myself of 20years, but i also understand that the sparks may need to operate the controls to perform his/her functional tests. There are always a need to keep the boiler running for the tenant, or circulate the cleaning chems in different situations, but a sparks turning a boiler on will never be responsilbe for its safe operation from a gas point of view (unless the case forms a combustion seal).
i would be happy for any electrican to assume any boiler i had fitted and left running to be safe to turn back on once they have done there work or any boiler i had left uncommissioned (disconnected and label'd)to be turned on to enable it to be electrically tested. I cant comment on other gas engineers bad practice's or blame any electrician for such.
