Discuss Heating in the Central Heating Systems area at ElectriciansForums.net
M
MNR
Never done a heating before can anyone point me in right direction. Read stickies but keep confusing myself. In kitchen under boiler sfs over to programmer from here I have two 3 cores up to wiring centre and a five core flex to boiler , two more 3 cores off to two separate thermostats. On pipe work by cylinder I have three valves or motors two look the same one is different. Any where I can find an idiots guide once I've done one maybe they won't be as scarey.
http://wiki.diyfaq.org.uk/images/thumb/0/0d/S-Plan-Wiring.gif/512px-S-Plan-Wiring.gif
Reply to Heating in the Central Heating Systems area at ElectriciansForums.net
Hello, I hope you are well, I have fitted a few Nests but only to Combi, S and Y plan systems just been looking a job where I’m doing the kitchen...
At the moment it depends on the weather on how well the central heating works, the main problem is the Nest Gen 3 thermostat only measures the...
Hi all, taken on a new build project and they have quite a large property with three separate manifolds. I have wired before with one manifold but...
Hey everyone, hope you all had a good xmas. Got called around to change over an old style pin type thermostat to a hive one for a family member...
