This thread uses a prefix to highlight that the thread involves something central heating related. Try to use prefixes more often peeps.
The boiler is a wallstar, needed a permanent live and a switched, apparently with the uh8 if you set up a rad zone or if there is a call for hw it will not turn on the UFH pump which is on a separate feed. Unfortunately most of my day was spent sorting out other issues before I could start on the job in hand.
I'm not familiar with that boiler, so it doesn't have pump over run? you need to set the thermostat for the rad zone to 01 so it doesn't kick in the UFH pump.
Thanks for all your help yesterday, much appreciated, went back today and finished off, then the boiler wouldn't fire up, not my issue as it all had power just kept locking out!:-)
Sounds like a similar problem to what I experienced. Am sure the next thing they tell you is that the pump is not compatible..... Best of luck....
No the boiler needed a service, all the controls are fine, happy customer and he rates the system, would definitely put another one in!:-)
