Discuss Help...fire detection in new small extension in the Industrial Electrician Talk area at ElectriciansForums.net
A
aaronstuart
Just first fixed a small one storey extension to a back of a house, extended the kitchen and dining room, only small, is it a requirement to install a smoke and heat detector in new extension?
Ask this as the builders had the BCO in and was told it has to have fire detection.
I always fit smokes in new builds, rewires and larger extensions ( 2 storeys etc ), customer is not too happy to fit ( as was not on passed plans ), even though a few extra quid installing could save lives..
Had a look through Part B but could not see anything regarding extensions only new habitable rooms?
Any advice appreciated
Many thanks
I do seem to recall two smoke alarms are required under Part P of the Building Regulations. One up and One down.
Maybe you could take a quick look at them to see where you stand with the extension?
any materially changed habitable property( any house that has had minimum a wal moved )needs interconn smoke and heats. It's work for us and I would defy anyone to say it shouldn't be done. If you didn't know this in the nicest posssible way "WAKE UP!!!!!"
Reply to Help...fire detection in new small extension in the Industrial Electrician Talk area at ElectriciansForums.net
