thebigjoe1
Restoring an old westinghouse desk fan from 1919. There are three wires coming from the fan head (motor) labeled G, Y, and R. Can these be identified for me, ie positive, negative, ground? Thanks!
Avo and Lucien,Antique Fan Collectors Association the place to go:
Hopefully that inductor/autotransformer component is still in good health!
That's great that you have a meter.Lucien, i have a multimeter, yet sadly am not an expert at using it. if you can give me some tips on how to properly use it so that i can take the necessary measurements, id greatly appreciate it.
Avo, The way you have your diagram, i tested late last night, and all i get is a hum from the motor when i switch it to on.
HiMy meter does not let me select the different levels, its an auto range meter.
So just putting them on the terminals of the AC, not plugged into wall, it measures in at .017. If i then put them on the red and black wires from the coil it read .041. Does that seem correct, and if so any issues?
