Hi, is that allowed? I'm in a course and my instructor said it could be dangerous if both contacts on the holder become live and someone unscrews (E26) a lightbulb and accidentally touches the cap and the ceiling/wall at the same time, closing a circuit. I won't do that but someone who doesn't knows might.Does this light have two switches? There's two wiring methods for two way switching that I use (yeah, old skool). One of the methods can leave both feed wires 'live' while the light will be off. Flip both switches and test again.
Can you give a drawing for that?Does this light have two switches? There's two wiring methods for two way switching that I use (yeah, old skool). One of the methods can leave both feed wires 'live' while the light will be off. Flip both switches and test again.
Feed L+N to both switches then run a single wire from each switch to the light.Can you give a drawing for that?
All feed wires are permanent lives it's only the switch wire that is dead when the light is turned off.
Normally on say, pendants or battens, the perm live will go to each light on the run and then an individual switch wire goes from the rose to each switch from each fitting. Can't picture the way you're saying.
