Discuss Help making a generator cord for my home! in the UK Electrical Forum area at ElectriciansForums.net
I
just purchased a generator with a 30 amp twist lock 4 prong outlet. My house has a generator outlet that has 3 prongs, see the attached pictures. It appears as though the outlet was wired using the black as a hot and the white wire also as a hot. I am making a generator cord and I have purchased the two plugs and 10/4 wire. My question is regarding the wiring on the 3 prong side. Would I connect the two hot wires (red and black) and neutral wire (white) and not connect the ground, and just ground the generator through a grounding rod?
Yes I am aware of the dangers of connecting a generator to a homes power grid and do have a transfer switch.
I don’t think that is a generator inlet, it looks like a power outlet.
The whole arrangement looks like a bodge and could easily be dangerous.
A registered electrician is what you need here, not some advice from a forum.
I View attachment 60938View attachment 60939just purchased a generator with a 30 amp twist lock 4 prong outlet. My house has a generator outlet that has 3 prongs, see the attached pictures. It appears as though the outlet was wired using the black as a hot and the white wire also as a hot. I am making a generator cord and I have purchased the two plugs and 10/4 wire. My question is regarding the wiring on the 3 prong side. Would I connect the two hot wires (red and black) and neutral wire (white) and not connect the ground, and just ground the generator through a grounding rod?
You need to make that generator cord a 4 wire application. Not a 3 wire
Reply to Help making a generator cord for my home! in the UK Electrical Forum area at ElectriciansForums.net
I am interested in having a home generator that would provide power to my home when the power is out during hurricane season, etc. I have 2...
Legends, need some advice. I am a 12v automotive electrician, but have had a side project building a concession trailer for my dad. We have an...
Hi, I'm a hobbyist without formal training. I'm looking to power audio/video equipment over several hundred feet of extension cords. I have 2...
