We don't know which is the switched live. Trial and error isn't a suitable method of testing. I would advise, as other have, that you get an electrician in. They'll be able to quickly determine which wire is which and place the terminations in a suitable enclosure.
Ok, I’ll do that, thank you for your help again, could you tell me what I should put the wires in to instead of them wagos? Thanks.
I meant to terminate the loose ones, the other person who replied advised I shouldn’t be using them in a ceiling void. Is that correct?
No connections with exposed basic cable insulation should be left in a ceiling void.
If it is a metal fitting I am wondering if it needs an earth or if it is deemed double insulated how you would go about correctly connecting it.
It is and it does have earth wires which I will also connect up, the previous person who had wired this left both earths (the one coming from the wires which was tied together and the one inside the pendant light which wasn’t even stripped and was left inside not connected to anything) not connected to any wagos or terminated.
Kent
United Kingdom
Trainee Electrician
Help need wiring a light
Lighting Forum
Thread Tags
R62538472,
R62538472,
