Fire rated down lighters are the ones with a metal can on the back of them.
They are designed to ensure that if there is a fire in the room then the resistance of the ceiling to the spread of fire is not compromised.
They are only required in rooms where the penetration of the ceiling leads into another dwelling (actually if it is penetration of a fire compartment) e.g. if there is a another flat above the room. They are recommended in other rooms but make no real difference to the spread of fire in the main.
They will not generally help with overheating as they tend to trap the heat in the can to some extent.
This is similar to the problem you get when any type of downlight is covered in insulation.
The only thing to help overheating (apart from changing the lamps to CFL or LED) is to check if your fittings are only designed for reflector lamps as opposed to dichroic lamps.
Dichroic lamps push heat backwards and can lead to more overheating (particularly if the lamp is covered)
Aluminium lamps only send heat forward and can lead to a cooler fitting.
If dichroic lamps are put in an aluminium only fitting the fitting can get too hot and cause problems.
Reflector lamps have a solid aluminium backing, dichroic lamps have a semi translucent pearlescent backing, not very obvious unless a light is shining through the backing.
It makes you think we are trying to deal with a potential fire hazard and get berrated for not installing them properly yet how come the standards people did not just ban them or is it just the fact that big business rules and the guys at the bottom of the ladder get the blame.
