Discuss Help on learning heating systems for domestic properties in the UK Electrical Forum area at ElectriciansForums.net
Could someone point me in the right direction for learning everything I need to know on heating systems throughout my apprenticeship I didn’t get to do a lot of it and would like to know my stuff . Thanks
If you google Honeywell heating wiring diagrams they are self explanatory. Most systems use either two port valves for HW and CH, or a three port valve to do both. Follow the wiring and you'll see how it works. Programmer feeds heating and HW stats, stat tells required valve to open, micro switch in valve switches on boiler and pump.
Don’t just go for the parrot fashion method of learning the systems..
Look into each device and how they work, draw out your own circuit diagram and work out how each system operates..
This will make fault finding and alterations to existing systems very simple
Honeywell (MK) do excellent training days touring the country, quite cheap as well.
Drayton (Schneider) also do courses but more for their excellent Wiser system and hub. Maybe worth a call to see if they do a 'basics' course.
Reply to Help on learning heating systems for domestic properties in the UK Electrical Forum area at ElectriciansForums.net
I'm in the middle of preparing a quote for installing 12 x 3Kw and 4 x 2Kw halogen heaters in a church. The system design was provided by a...
Hi Guys Recently finished a new build house, 2 levels/ 5 bed. Wired AICO grade D LD2 system throughout. LABC has come to sign off saying needs...
Hello fellow sparks, I’m looking to do my testing and inspection course which starts on the 30th of April, but I have not got much testing...
Hi As some of you will know . I'm studying level 2. I have the onsite guide. But does anyone know any books I can buy to help me understand...
Evening everyone . Currently looking at pricing a job up . It’s a hot tub supply . Outside socket with a few spare ways in an outdoor cu . 10mm...
