Discuss Help on PIRs required please in the UK Electrical Forum area at ElectriciansForums.net
M
moortown89
Hi there so today at work i was asked to add on a new pir onto a lighting circuit that already had 7 6ft fluerescent lights onto it and also an existing pir..i took a 4 core 1.5 from the old pir and brought it to the new one.. when i had everything connected in and the front part of the pir on (one of the pins types) and energised the circuit it tripped out straight away. when i had pull the front part of the pir out and turned the circuit back on it worked fine but once i tried to put the front of the pir back on it continued to trip.. it is currently protected by a B10 breaker any help or suggestions would be greatly appreciated
Reply to Help on PIRs required please in the UK Electrical Forum area at ElectriciansForums.net
Hi All, I need a bit of advice. My client is asking for a rather silly lighting setup in his bathroom and I am struggling to understand...
Hi. I'm an I.T.. engineer with some outdated electrical experience. I qualified C&G 2330 17th edition about 15 years ago, but my only experience...
Hi everybody. We had a Texecom system installed 3 years ago. Earlier this year we had a battery problem and the installer came back and changed...
Hello all. So I am sure the expertise on this forum will be able to decode this very easily. But it has completely baffled me. I'm in training so...
