So the fan comes on when I turn the light off? Then turns off on a timer?
What @telectrix was saying that your switch has two contacts (switches) inside it. When you switch on the light switch one contact will operate the light and the other will operate the fan.
If your fan has a timer then the fan usually operates when the light is switched on then run for the set time after the light is switched off.
London
Business Name
None
Help please for my bathroom light switch
Lighting Forum
Ben Webster,
Midwest,
