I'm surprised......I appear to be the only person on this forum who very rarly encounters faulty RCD's.
I have also been surprised by this especially as both incidents happened at the same location...the faulty rcbo is the first I have encountered but the MK rcd is a few years old and in a location which would leave it prone to dampness, dust etc...ideally the board should be an IP56 type enclosure but this would not be easy to achieve...however I do take on board the notion that the tester, once, calibrated may then be used without any further checks on its accuracy, apart from a check box and this would'nt help with the rcd function....?.
ashdail,
Acer,
